RisPort giving problem
Hi All,
Iam using RsiPort webservice to get the RealTime Information from call manager (CCM 5.0)but i am getting ERROR cam anybody help me out iam sending my request and response here
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:tns="http://schemas.cisco.com/ast/soap/"
xmlns:types="http://schemas.cisco.com/ast/soap/encodedTypes"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Header>
<tns:AstHeader id="id1">
<SessionId xsi:type="xsd:string">SessionId</SessionId>
</tns:AstHeader>
</soap:Header>
<soap:Body soap:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">
<tns:SelectCmDevice>
<Class xsi:type=\"tns:DeviceClass\">Phone</Class>
<Model xsi:type=\"xsd:unsignedInt\">255</Model>
</tns:SelectCmDevice>
</soap:Body>
</soap:Envelope>
Error Response is:
ERROR: Element type "soap:Envelope" must be followed by either attribute specifications, ">" or "/>".
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Header/><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>SOAP-ENV:Cli
ent</faultcode><faultstring>Element type "soap:Envelope" must be followed by either attribute specifications, ">" or "/>".</faultstring><detail>
<axl:Error xmlns:axl="http://www.cisco.com/AXL/1.0"><axl:code>5001</axl:code><axl:message>Element type "soap:Envelope" must be followed by either attr
ibute specifications, ">" or "/>".</axl:message><request/></axl:Error></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>************
in request what is href="id1",please any body tell me what this parameter
this is majour issue for me
Thanks in advance
Ravindra
mustafanafees Mon, 06/09/2008 - 00:05
Hi Ravindra
Has your problem been solved or still? i am having the same problem...
stephan.steiner Mon, 06/16/2008 - 08:21
  • Silver, 250 points or more
Check a few pages back... there's a thread started by myself asking for an example.. and the example I got works for me and I even posted another working example (both CCM5 and CCM6) which allows you to query the status of specific phones versus all of them.
Let us know if that sample works for you.
