mohammedmahmoud Fri, 04/27/2007 - 01:35
  • Green, 3000 points or more
Hi Rajeshac,
You can do so via 2 methods:
1. Configure the TACACS server to assign the user a certain privilege level, and then using the privilege command on the router, configure which commands can the user with this privilege level issue.
2. Configure the TACACS server to do authorization for the router, and configure the router to accept this command authorization, and then configure on the TACACS the commands that a user can issue. (recommended)
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804fde16.html
HTH, please rate if it does help,
Mohammed Mahmoud.
