CallManager AD 2003 integration
I have CallManager 4.2 integrated with AD 2003 DC running fine, customer wants to install a new AD 2003 with R2 (this needs some sort of Schema update), will I have any problems with existing CCM integration, is it just the case of un install the Plugin and re install? I couldn't find any docs on DC to AD 2003 R2 integration.
Also the customer runs Unity (Win 2000) UM4.0(5) with parter Exchange 2003 server, will the upgrade in DC from 2003 to 2003 R2 cause any problem? I believe I just need to re run the DC/GC reconnect tool in Unity. Again on the Cisco doc it says Unity can be member server of 2003 domain, but does not state about 2003 R2 environment.
many thanks
Mohamed Bari
CAE Technology Services
UK
mchandak Fri, 04/27/2007 - 16:45
AFAIK, this should work fine as long as you re-install AD plugin on CallManager.
EDIT: For Unity, if you are going to build a new domain, Unity will have to be re-installed
