collision pro
Answered Question
Apr 27th, 2007
HELLO FRIEND
I have cisco 2522 router, it is directly connected to a cisco 1900 switch. While telnet to 2522 router it gives very slow response.
Correct Answer by mohammedmahmoud about 9 years 8 months ago
Hi there,
As far as i can say, the problem in such cases is always related to either Duplex mismatch, cabling problems or high CPU utilization on the router.
HTH,
Mohammed Mahmoud.
Overall Rating: 3.5 (2 ratings)
mohammedmahmoud Fri, 04/27/2007 - 04:19
Hi there,
Kindly check the speed/duplex on both sides.
HTH, please rate if it does help,
Mohammed Mahmoud.
rbforever25 Fri, 04/27/2007 - 04:35
hi
thanks
but we had allready tried that, it reduced late collision, but no change in its access speed.
Correct Answer
mohammedmahmoud Fri, 04/27/2007 - 04:38
Hi there,
HTH,
Mohammed Mahmoud.
