VPN3K L2L Netscreen with X.509
Apr 27th, 2007
Hi all,
we try to establish a site-to-site vpn with VPN3015 and Netscreen Firewall with
RSA Certificates.The tunnel comes up, if it is initiated by the side of Netscreen,
but it fails when the VPN3K tries to open it.Here is what we see in the Netscreenlog :
IKE<-.-.-.- > Process [ID]:
IKE<-.-.-.- > ID received: type=ID_DER_ASN1_DN, DN = Email=... CN=...,OU=...,O=...,C=..., port = 0, protocol=0
IKE<-.-.-.-> Received incorrect ID payload: ID type mismatch.
IKE<-.-.-.-> ID processed. return 1. sa->p1_state = 2.
IKE<-.-.-.-> Error processing ID
IKE<-.-.-.- > Phase 1: Main mode
negotiations have failed.
The Netscreen is awaiting to get the ID type ID_FQDN,but the VPN3K sends the ID ID_DER_ASN1_DN. We also changed the value of the DN Field in Configuration|Usermanagement|Groups|IPSec,but nothing changed.How will it possible to send the right ID to Netscreen ?
Thanks and regards
Volker
drolemc Thu, 05/03/2007 - 11:27
Try using ip address instead of DN and see if it works.
