How to configure route filter for accessing carrier Operator
Apr 27th, 2007
I want to use route-filter when end user dials 9.0, 9.0#, 9.01,9.01# for carrier operator or using calling card to finish the call.
Is there anyone let me know why the following route-filter does not work?
Route Filter Name: BOperator
Clause: (INTERNATIONAL-OPERATOR EXISTS) OR
(INTERNATIONAL-OPERATOR EXISTS AND END-OF-DIALING EXISTS) OR
(INTERNATIONAL-ACCESS EXISTS) OR
(INTERNATIONAL-ACCESS EXISTS AND END-OF-DIALING EXISTS)
When I dials 9.0 or 9.0#, I heard "your call can not be completed.."
JJ
dennisbehrens Sun, 04/29/2007 - 18:13
I believe you need to also include "LOCAL-OPERATOR" which would be "9.0". If you wanted to include "9.00", you would need "LONG-DISTANCE-OPERATOR".
I hope this helps,
Dennis
**Please Rate My Post if it's helpful **
