CAS channel order
Apr 27th, 2007
We know we can use this command to change the order for PRI outbound call
"isdn bchan-number-order"
But is there any command for Cas? Thanks
Overall Rating: 4 (2 ratings)
Paolo Bevilacqua Fri, 04/27/2007 - 07:50
You can define the order that you want on CAS.
Suppose you create one ds0-group per timeslot, that will create 24 voice-ports for T1.
These 24 voice-ports you will re-group together in a trunk-group, each one with a preference that will ultimately define the order in which they are used, or other schemes if you want.
Then the DP will reference the single trunkgroup above.
ciscoforum Fri, 04/27/2007 - 09:22
Here is the followup question.
1.How can we re-group them in one trunk-group in H323 router?( My scenario does not have CCM). Just PBX-GW----IP-----GW-PBX
2.You know what's the default order on CAS if only group for the channels?
Paolo Bevilacqua Fri, 04/27/2007 - 11:15
[approximate config follows]
controller t1 1/0
ds0-group 1 timeslots 1 type e&m-wink
ds0-group 2 timeslots 2 type e&m-wink
ds0-group 3 timeslots 3 type e&m-wink
voice-port 1/0:1
trunk-group pbx 1
voice-port 1/0:2
trunk-group pbx 2
voice-port 1/0:3
trunk-group pbx 3
trunk group pbx
hunt-scheme sequential
dial-peer voice 10 pots
destination-pattern 4...
incoming called-number 3...
trunkgroup pbx
As a courtesy to those providing answers, please rate all useful posts!
