Cisco 7960 with VoipBuster
Answered Question
Apr 27th, 2007
Hi All,
I've changed my Cisco 7960 firmware to SIP. Also I've configured my phone to call with VoipBuster, but it don't work.
When I turn on my phone, the settings will be downloaded from my TFTP-server. When I go to my SIP configuraton, I see the right Proxy, port, username and password, but in my main screen I see in the top (corner) "VOIPBUSTER SIP" with a phone icon. But in that phone icon, there is a "X". When I try to dial a phone number, the phone say:
To: 0031600000000 (Phone number)
Calling (out INV)
After 180 seconds (i think) the phone says: Reorder.
What do I wrong?
Firmware: P0S3-08-2-00
SIP Configuration:
Shortname: UNPROVISIONED
Authentication Name: XXXX
Authentication Password: XXXX
Display Name: VoipBuster
Proxy Address: sip.voipbuster.com
Proxy Port: 5060
Danido.
Correct Answer by Paolo Bevilacqua about 9 years 11 months ago
Ok, in phone config file you may have:
try to set 1 and your public address respectively.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 04/27/2007 - 08:26
  • Hall of Fame,
    Founding Member
Hi Danido,
Is the phone behind NAT?
Can you take an ethereal trace to see what is going on?
Klavertje19 Sat, 04/28/2007 - 14:50
Yes, my phone is behind a NAT.
Now I forward this ports to my Phone:
Any 8585 - 8585
Any 5060 - 5070
Any 16384 - 16484
UDP 123 - 123
UDP 69 - 69
But it don't work.
The Show Reg command (with telnet) show's the following:
1 .1x REGISTERING 3600 31 sip.voipbuster.com:5060
Note: APR is Authenticated, Provisioned, Registerd
I've already searched the forums, but I can't find the solution.
Danido
Correct Answer
Paolo Bevilacqua Sat, 04/28/2007 - 16:36
  • Hall of Fame,
    Founding Member
