QoS lab scenario?
Apr 27th, 2007
I have been trying to figure out answer to this for a long time without any success. I need to configure QoS for my CCIE lab and then test it. I was looking for a sofware that can generate enough traffic to triggger QoS and create flow on various ports and protocols. I can to test LLQ and CBWFQ. Can experts here please suggest me if theres any tool that can do it easily for me?
Thanks a ton,
Overall Rating: 5 (1 ratings)
srue Fri, 04/27/2007 - 09:34
try google'ing "traffic generator" or "voice traffic generator". looks like there are a few free tools that can do this. I don't have any experience with any specific tools in this category though. anyone else?
royalblues Fri, 04/27/2007 - 11:38
I have tried using the network traffic emulator. It does generate traffic but i never understood the amount of traffic it generated when you define the number of packets
you can also try traffic emulator
Also there are lot of other free/shareware tools available on the net with which you can test your QoS settings
HTH, rate if it does
mrunal_47 Mon, 05/07/2007 - 12:28
Hey this is for basically Linux based machines. Any ideas about Window based machines?
