VLANs
Answered Question
Apr 27th, 2007
Hi.
I have Cisco 1801.
I have created 2 vlan.
Vlan1 is 8 static ip, from my provider
Vlan2 is 8 dynamic (internal 192.168.0.1???)
My problem:
Vlan1 have internet access
Vlan2 not.
When possible give to me link to manual, or small Example.
Sorry about my English.
Best Regards Andriy Harisios.
Correct Answer by royalblues about 10 years 1 month ago
You would require a NAT?PATconfiguration for your Private VLAN to access internet
Use any one IP from the pool provided by your ISP (say for eg.. if it is 1.1.1.1 )
ip nat pool Internet 1.1.1.1 1.1.1.1 prefix-length 29
ip nat inside source list 104 pool internet overload
access-list 101 permit ip 192.168.1.0 0.0.0.7 any
interface
ip nat inside
interface
ip nat outside
HTH, rate if it does
Narayan
Overall Rating: 5 (1 ratings)
pstebner1 Fri, 04/27/2007 - 10:50
Andriy-
Can you clarify? I assume that your ISP gave you 8 public IPs.
Are you wanting to set this up so that VLAN2 does not have access to the net or are you saying that right now VLAN1 has access and VLAN2 does not, but you want it to?
Also, if you have any config on the 1801 please post it.
Paul
andriyhar Fri, 04/27/2007 - 11:11
Question:
How to make the Internet on VLAN2
User Access Verification
Username: andriy
Password:
Cisco-1801#sh running-config
Building configuration...
Current configuration : 4839 bytes
! Last configuration change at 19:04:36 london Tue Apr 24 2007 by andriy
! NVRAM config last updated at 18:47:19 london Tue Apr 24 2007
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Cisco-1801
boot-start-marker
boot-end-marker
logging buffered 4096
no aaa new-model
clock timezone london 1
clock calendar-valid
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp ping packets 4
ip dhcp pool pool1
network 91.84.00.00 255.255.255.248
default-router 91.84.00.00
dns-server 212.104.000.0 212.104.000.00
lease infinite
ip dhcp pool pool2
network 192.168.0.2 255.255.255.248
lease infinite
ip tcp synwait-time 10
no ip bootp server
ip name-server 212.104.000.0
ip name-server 212.104.000.00
ip ssh time-out 60
ip ssh authentication-retries 2
ip inspect name voip sip
crypto pki trustpoint TP-self-signed-1050249944
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1050249944
revocation-check none
rsakeypair TP-self-signed-1050249944
username andriy privilege 15 password 000000000000
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 0/38
encapsulation aal5snap
protocol ppp dialer
dialer pool-member 1
interface Vlan1
ip address 91.84.00.00 255.255.255.248
ip access-group vlan1_in in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
interface Vlan2
ip address 192.168.0.1 255.255.255.248
no ip redirects
no ip unreachables
ip nat outside
interface Dialer0
ip address negotiated
ip access-group dialer0_in in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname [email protected].00000000.00.00
ppp chap password 7 151B010D07253E2927
ppp pap sent-username [email protected].00000000.00.00 password 00000000000000
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
ntp clock-period 17180201
ntp server 213.170.141.38 prefer
ntp server 194.150.121.14
ntp server 81.187.121.162
end
Correct Answer
royalblues Fri, 04/27/2007 - 11:12
  • Green, 3000 points or more
interface
ip nat inside
interface
ip nat outside
Narayan
pstebner1 Fri, 04/27/2007 - 12:35
FWIW, there's a typo in the above config. The source list should be 101, not 104.
HTH,
P
