Cannot SSH into PIX
Answered Question
I would like to be able to use an SSH client to connect to my PIX firewall over the Internet. I can do this to my 506 PIX but not on my 515, with debug SSH on I keep seeing "invalid userid michael" even though I have put the command "user michael password michael privilege 15" into the configuration. What am I doing wrong?
Correct Answer by Patrick Iseli about 10 years 3 weeks ago
Have you created a rsa key ?
#Generate a key:
ca generate rsa key 1024
show ca mypubkey rsa
#Save ssh key:
ca save all
#Allow incomming ssh connections:
ssh ip_address [netmask] [interface_name]
aaa authentication ssh console LOCAL
sincerely
Patrick
Overall Rating: 5 (1 ratings)
Correct Answer
Patrick Iseli Fri, 04/27/2007 - 12:02
  • Gold, 750 points or more
#Generate a key:
#Save ssh key:
ca save all
sincerely
Patrick
sundar.palaniappan Fri, 04/27/2007 - 12:04
  • Green, 3000 points or more
Michael,
Have a look at this document and make sure that you have all the configuration required to allow SSH access from the outside host.
http://cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008069bf1b.shtml#conf
If you are still having problems post the sanitized configuration and debug ssh output.
Sundar
oabduo983 Sat, 04/28/2007 - 10:25
  • Bronze, 100 points or more
YOU ARE MISSING:
Otherwise, use pix as username and your telnet password to access your unit!
Please rate this post if it was helpful!
