High CPU
Apr 27th, 2007
Hi Guys,
Our Customer have one 7600 that is presenting problem of performance. When I type "show proc cpu sorted" in the interface GE-WAn display the process "CEF Scanner" in 60%. What it is this process? which is its affectation?
Danilo Dy Sun, 04/29/2007 - 07:01
What is your IOS version? Please post "show version" output.
CEF Scanner process computes new L2 adjacency when there is a MAC rewrite.
Dandy
wilsonsant Wed, 05/02/2007 - 04:12
Hi Dandy,
It follows below the show version
The version is 12.2(18)SXF4
Thank You,
Wilson
guruprasadr Sun, 04/29/2007 - 23:12
HI Wilson, [Pls Rate if Helps ! !]
We too had the same problem of over loaded CPU of 7206 VXR Router upto 85% in a Site.
After several Investigations, we already had "Netflow" implemented in our Routers. Noticed that Several Client IP's in BO has communicated to single IP in HO for particular service & initiated more than 1000 IP sessions. This made the CPU Load go High upto 85%
So, without any best analyser like "Netflow" you will not be able to Investigate & Identify the Root Cause for this Situation.
Pls Rate If Helps ! !
Best Regards,
Guru Prasad R
mohammedmahmoud Wed, 05/02/2007 - 04:46
I add my voice to Guru, enable Netflow on the interface and try to investigate any malicious traffic.
interface x
ip route-cache flow
and then do "sh ip cache flow".
HTH, please rate if it does help,
Mohammed Mahmoud.
