Cisco IP communicator for Linux
carlostrapiello
I have Open Suse 10.2 in my home and I would like to use Cisco IP Communicator here to connect to my branch office where CCM 4.1 is installed.
Is there a Cisco IP Communicator version for my linux distribution?.
Any other seemed application?.
Thanks.
Brandon Buffin
SJ Labs makes a softphone compatible with Linux.
www.sjlabs.com
Hope this helps. If so, please rate the post.
Brandon
Did you try it?.
I have more dudes. Can I call all phone types from my call manager with this siftware without any other service?.
No, I have not tried this product. Yes, you can call any phone on your CCM with this software.
Brandon
I will try it and I will comment you results.
Thanks.
