CiscoWorks 2000
Answered Question
Apr 27th, 2007
Hi Netpros,
I have a small issue with my CiscoWorks. My company has an old version of CiscoWorks 2000 with RME 3.3, DFM 1.1, CDone 4th Edition and so on. I think it was purchased around 4 to 5 years back. My company is keen on using it for time being, once they are satisfied about its perfomance then they would go for the latest version. The problem is I could not find any relevant decumentation about its installation and configuration and fine tuning. Any help on this will be highly appreciated. The Server I will be using is having 2GB RAM, I think that would be enough i suppose.
TIA
Faiz
Overall Rating: 4 (1 ratings)
Mohammed Faiz M... Fri, 04/27/2007 - 23:49
Thank you very much. I know it will be difficult for me if I get stuck in any problems while configuring it, since its not supported now. But still i hope these links to the documentation will be helpful.
Faiz
