NATIVE VLAN on 4006(CAT OS )Switch
Apr 27th, 2007
HI,
How can we configure Native Vlan on 4006(CAT OS) switches??
Thanks in Advance.
Overall Rating: 5 (1 ratings)
balajitvk Sun, 04/29/2007 - 03:06
To control the tagging of the native VLAN traffic on 802.1Q private VLAN trunks, use the tag command.
switchport private-vlan trunk native vlan
Rate if it does,
jeff.teoch Wed, 05/02/2007 - 01:04
You just need to put in the command "set vlan " on the trunk port and the trunk port with that vlan set will be the native vlan automatically.
Jeff
glen.grant Sat, 05/05/2007 - 09:38
The native vlan on a 4006 is simply the vlan to which the port is set if the port is not trunking . To set the vlan as the previous poster said "set vlan x slot/port " .
