cpu load thr MRTG
i have this version of switch:
Switch#sh ver
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)XU, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 03-Apr-00 17:31 by swati
Image text-base: 0x00003000, data-base: 0x00301398
ROM: Bootstrap program is C3500XL boot loader
Switch uptime is 1 hour, 39 minutes
System image file is "flash:c3500XL-c3h2s-mz-120.5-XU.bin"
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes of memory.
Processor board ID 0x17, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:02:B9:B8:C7:40
Motherboard assembly number: 73-3903-04
Power supply part number: 34-0971-01
Motherboard serial number: FAA04299PML
Power supply serial number: PAC042801MZ
Model revision number: A0
Motherboard revision number: B0
Model number: WS-C3548-XL-EN
System serial number: FAA0428F1HV
Configuration register is 0xF
i need to monitor the CPU Load for this switch;can i know the MIB OR OID To use it in my cfg file?
Overall Rating: 5 (2 ratings)
royalblues Sat, 04/28/2007 - 08:35
I did not find the MIB for this switch in the Cisco MIB locator.
However we use solarwinds and it is able to poll a 3548XL for CPU load.
Will try to find out the OID from the solarwinds database
Amit Singh Sat, 04/28/2007 - 08:57
Hi Ali,
Which Network Management software are you using in the network? I have few customers of mine using the same CPU load montioring with HO Openview Unicenter. They have built in OID's to montior the CPU load for devices.
-amit singh
Danilo Dy Sun, 04/29/2007 - 06:30
Hi Ali,
I'm not using 3500 anymore. I use mrtg to monitor cpu, memory and disk of win2k3 and linux servers and cpu, memory, and interfaces of pix firewalls. I use cricket primarily for cisco devices. I'm able to run cricket in windows 2k3.
However, try this for 3500;
Target[hostname.cpu]: .[email protected]
m_elbatniji Sun, 04/29/2007 - 23:54
I am using the same OID I found on MRTG website (http://oss.oetiker.ch/mrtg/doc/mrtg-nt-guide.en.html) check the example at the end of the page. I didn't know that there are different OIDs for CPU for each model. I have different models in my network (6513,4507,3750) and I have configured MRTG to monitor the CPUs of all these model using the same OID:
Target[traget_CPU]:[email protected]
So far I am getting results from MRTG on CPU usage from all models. So try that OID. Please anyone let me know If I really should be using different OIDs for each model. Thanks.
Joe Clarke Sun, 05/13/2007 - 17:21
The OID is avgBusy5 from the OLD-CISCO-SYS-MIB. This OID is deprecated, and may not be accurate for all devices. It certainly will not work for CatOS devices. A more current OID is cpmCPUTotal5min ( from the CISCO-PROCESS-MIB. It, too, is deprecated, but it much more universally supported. The best object to use (provided your device is new enough to support it) is cpmCPUTotal5minRev (
There is a big difference between these two objects and avgBudy5, though. The two cpmCPUTotal5min objects are part of a table, and so they will have non-zero instance numbers. Before you can use these objects in MRTG, you will need to figure out which instance to monitor. Typically, the instance you want will be 1 (for example, this will always be 1 on the 3750), but on multi-CPU boxes, you may want to monitor all CPUs. So you should first walk the cpmCPUTotalTable ( to see which CPU instances you can monitor, then configure MRTG accordingly.
