Curious: can a WAN ACL block outgoing http, or must a LAN ACL be used?
Apr 28th, 2007
This works:
access-list 151 remark Block insecure connections to myaccount.simplicato.com's current (as of ACL edit time) IP.
access-list 151 deny tcp any host myaccount.simplicato.com eq www log
where ACL 151 is applied to the LAN interface:
ip access-group 151 in
But shouldn't
access-list 150 deny tcp host myaccount.simplicato.com eq www any log
where ACL 150 is applied to the WAN interface:
ip access-group 150 in
have worked too?
It didn't work. Is this because the connection starts from the inside, and gets established before this rule has a chance to stop it, and the implicit rules for established traffic make this ineffectual or what? Just trying to learn.
Overall Rating: 5 (2 ratings)
Jon Marshall Sat, 04/28/2007 - 12:15
Router access-list are not stateful, unless you are usng CBAC which is the IOS firewall.
Are these the full access-lists that you applied. Also do you have an ip host mapping for myaccount.simplicato.com on the router ?
Jon
melvey Sun, 04/29/2007 - 16:30
I'm using a 1721 (running IOS: c1700-advsecurityk9-mz.124-3a.bin).
No, the ACLs are longer (ACL 150 is LONG; I'd have to sanitize it extensively to post it.) I guess you think there may be a rule of higher priority that is overriding my otherwise correct-looking rule. Is that your thinking? If so, I can clean it up and post it. (I just looked over 150 again, and it looks fine.)
The router converts the hostname to an IP when it's entered, as I indicate in the comment, perhaps a bit cryptically. If I did a show run, it had been replaced with the IP that was assigned to that hostname at the time - admittedly, a shortcoming.)
Thanks!
Jon Marshall Sun, 04/29/2007 - 23:01
Could you post the full router config (minus any sensitive information)
Jon
Richard Burts Mon, 04/30/2007 - 07:10
As Jon indicates a sanitized config would be helpful. But before you spend time doing that, perhaps you can tell us whether there is a permit tcp established rule in the access list before the rule for myaccount... If so that would explain the behavior: if someone inside initiated a connection to myaccount... the return packets have the ACK bit set and the established rule will let them through, and it never gets to your more specific rule.
I agree that the syntax of what you posted looks ok and should work, unless there is something in the rules that applies before you get to this rule.
Rick
