mirboukai Mon, 04/30/2007 - 08:47
thank you osama
but is there another solution.
regards
Muzaffar :)
mirboukai Mon, 04/30/2007 - 08:48
thank you osama
regards
Muzaffar :)
rochopra Mon, 04/30/2007 - 16:59
only ACS se v3.3.3 and v4.0 can be upgraded to ACS v4.1.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacsapp/csapp41/igse41/upgap.htm#wp1056333
To go from ACS v3.2 to v4.1 you have to follow the following process
v3.2 to v3.3.3 then v3.3.3 to v4.1
To do the same you will require the following image names:
ACSse-Upgrade-Full-v3.3.3.11-K9.zip
ACSse-Upgrade_CD-v4.1.3.12-K9.zip
