C4506 int gig port speed nonegotiate
Answered Question
Apr 28th, 2007
Hi all,
I have a C4506 with gig int, that is showing me speed nonegotiate, I need to remove this config from the gig int, but the IOS shows no other option then nonegotiate. how can i achinve this.
C4506-01#sh run
interface GigabitEthernet3/6
speed nonegotiate
Raj
Correct Answer by balajitvk about 10 years 9 hours ago
Hi RK,
For fiber Gigabit Ethernet interfaces, the default is "no speed nonegotiate", which sets the speed to 1000 Mbps and enables link negotiation for flow-control parameters and remote fault information. The "speed nonegotiate" command disables link negotiation.
So if you want negotiation, it is as simple as other commands,
"no speed nonegotiate" command.
http://www.cisco.com/en/US/products/ps6845/products_configuration_guide_chapter09186a00806e9f38.html#wp1040549
Rate if it does,
Rgs
Overall Rating: 4.5 (2 ratings)
rkcontrol Sun, 04/29/2007 - 21:27
It worked with the No SPEED command.
RgdsRaj
Correct Answer
balajitvk Sun, 04/29/2007 - 10:20
  • Silver, 250 points or more
Hi RK,
Rate if it does,
Rgs
rkcontrol Sun, 04/29/2007 - 21:29
The only option was NO SPEED command it solved the problem.
Rgds
Raj
