pix to router
Apr 29th, 2007
hello,
can anyone tell me what would be the opposite command in pix FW if i want to do the same in router
pix command
static (outside,inside) 172.20.6.2 172.32.5.7 netmask 255.255.255.255 0 0
static (inside,outside) 60.10.72.136 172.16.23.1 netmask 255.255.255.255 0 0
mahmoodmkl Sun, 04/29/2007 - 03:45
First u r statement in pix is wrong.
it should be.
static (inside,outside) (gobal ip) (local ip) netmask
The second statement is ok.
what exactly u r trying to accomplish.if u want the inside host to use the same ip address while going outside then u can use the below syntax.orelse give us more details.
ip nat inside source static 172.120.6.2 172.32.5.7
Mahmood
zulqurnain Sun, 04/29/2007 - 04:03
hello mahmood.
all i want to do is this..
i want to nat the source address of the packet coming into the router
then i want to creat a one-to-one mapping with the new source natted ip address.
e.g.
source 1.1.1.1 = 2.2.2.2
when the destination will reply back to the packet 2.2.2.2 should again nat back to 1.1.1.1
hope its clear enough.
rais Sun, 04/29/2007 - 03:46
Opposite will be the command preceded with a 'no'.
If you looking for a router command use:
ip nat outside source static 172.32.5.7 172.20.6.2
ip nat inside source static 172.16.23.1 60.10.72.136
Thanks.
