TTL differnt value in ping
Apr 29th, 2007
when i ping i get reply with a differnt TTL, i want an explanation for that problem....
Thank you for your help
Ahmed Tantawy
N.B.,a snapshot to the ping is attached.
Overall Rating: 5 (1 ratings)
mohammedmahmoud Sun, 04/29/2007 - 04:18
This means that for some reason the 3rd and 4th packets took a different path with less routers in it (TTL is reduced by one when passing through a router).
HTH, please rate if it does help,
Mohammed Mahmoud.
eng_ahmed_tantawy Sun, 04/29/2007 - 05:32
Thanks for your respond but i ask for the reason uopn which this case makes me crazy thinking of it.
Thank you
mohammedmahmoud Sun, 04/29/2007 - 05:50
As far as i can say, the TTL value in the received packet will be 255 minus the number of routers in the round-trip path. The 3rd and 4th packets have found another path on the internet while traveling to/from the destination and thus they took it.
Mohammed Mahmoud.
