scottmac Sun, 04/29/2007 - 19:11
For the SIMs? Yes, it is / was.
You do not (usually) get the complete list, and there might be a few ringers.
If you rely on hitting the "?" a lot, there's a good chance you'll time-out on the test.
Learn the commands; plan on only using the "?" as (at best) a reminder or to verify thast the command you suspect is correct is valid.
Good Luck
Scott
