FXO trunk-group
Apr 29th, 2007
I have configured 8 fxo ports as members of a singe trunk-group. How do I get the ports to roll over to selecting the next available port if the higher pref ports are not available. By not available I mean phone line not plugged in.
The trunk group will select the highest pref port first and make a call, but if I move the phone line to another FXO port it will not hunt to the new port where i moved the line to, unless I make the new port a higher pref.
This is with outgoing calls.
I'm sure I'm missing something....thanks.
Overall Rating: 3.5 (3 ratings)
paolo bevilacqua Mon, 04/30/2007 - 01:44
  • Hall of Fame,
    Founding Member
The FXO hardware cannot detect automatically if it is connected to a line or not. So, you must manually shutdown ports that are part of a trunk-group but not connected.
Hope this helps, please rate all useful posts using the scrollbox below!
m-ketchum Mon, 04/30/2007 - 07:09
The more I researched the more I became afraid of that. Thanks for the info.
On another note, I decided to config my 3 PRI's as 3 seperate trunk-groups and the 8-FXO's as a 4th trunkgroup. Then I tied the 4 trunk-groups with pref to each of my dial-peers. Do you forsee any issues with this type of config?
interface Serial0/0/0:23
description <== PRI 1 ==>
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
trunk-group pri_1
no cdp enable
interface Serial0/0/1:23
description <== PRI 2 ==>
no ip address
encapsulation hdlc
trunk-group pri_2
no cdp enable
interface Serial0/1/0:23
description <== PRI 3 ==>
no ip address
encapsulation hdlc
trunk-group pri_3
no cdp enable
voice-port 0/2/0
trunk-group backup_fxo 1
connection plar opx 3232
voice-port 0/2/1
trunk-group backup_fxo 2
voice-port 0/2/2
trunk-group backup_fxo 3
voice-port 0/2/3
trunk-group backup_fxo 4
voice-port 0/3/0
trunk-group backup_fxo 5
voice-port 0/3/1
trunk-group backup_fxo 6
voice-port 0/3/2
trunk-group backup_fxo 7
voice-port 0/3/3
trunk-group backup_fxo 8
dial-peer voice 1050 pots
trunkgroup pri_1 1
trunkgroup pri_2 2
trunkgroup pri_3 3
trunkgroup backup_fxo 4
description <== Local ==>
destination-pattern 9[2-9]......
forward-digits 7
dial-peer voice 1051 pots
trunkgroup pri_1 1
trunkgroup pri_2 2
trunkgroup pri_3 3
description <== Long distance ==>
destination-pattern 91..........
forward-digits 11
dial-peer voice 1052 pots
trunkgroup pri_1 1
trunkgroup pri_2 2
trunkgroup pri_3 3
description <== Special service ==>
destination-pattern 9[2-9]11
forward-digits 3
dial-peer voice 1053 pots
trunkgroup pri_1 1
trunkgroup pri_2 2
trunkgroup pri_3 3
description <== International ==>
destination-pattern 9011T
dial-peer voice 1054 pots
trunkgroup pri_1 1
trunkgroup pri_2 2
trunkgroup pri_3 3
description <== 911 Safeguard ==>
destination-pattern 911
paolo bevilacqua Mon, 04/30/2007 - 07:18
  • Hall of Fame,
    Founding Member
I think it would be no issue. Trunk groups lets you mix and match different type of voice ports as you like.
In fact, if you merge pri_1, 2, 3 and backup_fxo into a single one, it would have the same effect. You would then assign the preference at interface level (trunk-group XXX ), and use a single "trunkgroup" statement in the dial-peer.
As a courtesy to those providing answers, please rate all useful posts using the scrollbox below!
