spremkumar Sun, 04/29/2007 - 21:04
Hi Ajay
The ip address you configure on the LAN interface mostly on the ethernet which connects to your local network will be the same as your default gateway set in the network properties..
regds
Jon Marshall Sun, 04/29/2007 - 22:58
You could mean one of 2 things.
1) You have configured an interface on the router for a subnet eg.
subnet 192.168.1.0
subnet mask 255.255.255.0
router interface 192.168.1.1
Any clients you attach to this subnet should have their defautl gateway in network properties set to 192.168.1.1
2) You have configured a default route on the router eg
0.0.0.0 0.0.0.0 "next-hop ip address"
If this is the case this would not be the same as the default gateway on the pc.
Jon
guruprasadr Mon, 04/30/2007 - 00:10
HI Ajay, [Pls Rate if Helps]
Please let us know about your network.
PC Address Allocation:
IP Address:
Subnet Mask:
Default Gateway:-->IP Address of Core Switch
Core Switch-->Static Route to-->Router
Router--->Static Router-->ISP
Else:
IP Address:
Subnet Mask:
Default Gateway:-->IP Address of Router Interface [belongs / Conencted to LAN Subnet]
Pls Rate If Helps ! !
Best Regards,
Guru Prasad R
Anand Narayana Mon, 04/30/2007 - 05:32
Hi Ajay,
IP address of the ethernet interface will be the gateway IP address for the clients in the LAN.
hope this helps.
rate this post if satisfied.
Richard Burts Mon, 04/30/2007 - 06:05
Ajay
Your question is not clear. Most of the time when we talk about configuring default gateway on a router we are talking about configuring a default route on the router. I am not sure if this is what you are talking about or not. The default route configured on a router is not propagated to the end stations as their default gateway.
It is possible to configure DHCP on a router and in configuring DHCP it is possible to configure a gateway address (usually the interface address of the router) which will be propagated to the end station and which will be the gateway address in network properties. I am not clear whether this is what you are talking about.
If this does not answer your question then perhaps you can clarify.
Rick
