royalblues Sun, 04/29/2007 - 23:10
Will they be connected to anything else or you just need to conenct only these laptops.
i think a 2960G would be sufficient for you
C2960G-24-TS-S
Narayan
Nadersarieddine Sun, 04/29/2007 - 23:36
Hi Narayan,
Thanks for your support, yes laptops to be connected alone. Is C2960G-24-TS-S for wireless connection also?
royalblues Mon, 04/30/2007 - 01:31
No you cannot use C2960G-24-TS-S as a wireless access point.
you can connect a wireless access point to one of the ports and use it though
HTH,
Narayan
