Application service problem
marco
For night service we have created a loopback voip dial-peer to with an application service that prompts a message during after hours.
During working hours the same DP will prompt a waiting message.
So the DP is called by setting up a "call-forward noan 5500 timeout 20" where 5500 is the number associated to the loopback voip DP.
Here is the DP configuration:
dial-peer voice 500 voip
service script1
destination-pattern 5500$
session target ipv4:192.168.1.1 <-- this is the router ip address (IF Gi0/0)
incoming called-number 5500$
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
The voice service voip is configured as follows:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
h450 h450-2 timeout T4 10000
h450 h450-3 timeout T1 10000
h245 caps mode restricted
modem passthrough nse codec g711alaw
sip
When the call starts from internal ephone or from outside mobile phones, the prompt is regularly played.
But when the call comes from an outside fixed phone, the call is disconnected just after the timeout for call-forward is expired.
We have also tried to configure a number expansion to call directly the DP 500 adding the following command to the configuration:
num-exp 2xxxxxx98 5500
but obviously the behavior does not change.
With "debug q931" we see that the call is disconnected with Disconnect Cause 10 (normal call clearing):
Apr 27 18:45:09.361: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x2500
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18387
Preferred, Channel 7
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '2xxxxxxx'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '2xxxxxx98'
Apr 27 18:45:09.365: ISDN Se0/0/0:15 Q931: TX -> SETUP_ACK pd = 8 callref = 0xA500
Channel ID i = 0xA98387
Exclusive, Channel 7
Apr 27 18:45:09.393: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xA500
Cause i = 0x8090 - Normal call clearing
Apr 27 18:45:09.461: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x2500
Apr 27 18:45:09.461: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA500
Any ideas?
Thanks a lot.
Marco.
6 Replies 6
paolo bevilacqua
Hi Marco,
It may be a problem with the script. When I set my ephone CFA to a AA-BACD in lookpback, and I call from pstn, I'm correctly routed to it.
What the script does for handling the call/ Just leg_incoming ?
Hello Paolo,
First of all sorry, but I've duplicated my request by mistake in the "IP Telephony" section:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dde5286
The script accepts the call
leg setupack leg_incoming
leg proceeding leg_incoming
leg connect leg_incoming
and then recalls media play to play the prompt, repeat the prompt another time and after the second play it closes the call with "leg disconnect leg_incoming".
In the tests we?ve done we have enabled the "debug voip app tclcommnads". When a call comes from a mobile phone the script was called and proceed successfully.
But when the call comes from the fixed phone number the debug print messages up to the "leg setupack" statement. The call is disconnected with a "clear disconnect cause".
Here is the debug output for a fixed phone call:
Apr 28 17:15:20.391: //6699//TCL :/tcl_InfotagObjCmd: infotag get leg_ani
Apr 28 17:15:20.391: //6699//TCL :/tcl_InfotagGetObjCmd: infotag get leg_ani
Apr 28 17:15:20.391: //6699//AFW_:/vtr_lg_ani: argc 2 argindex 2
Apr 28 17:15:20.391: //6699//TCL :/tcl_InfotagObjCmd: infotag get leg_dnis
Apr 28 17:15:20.391: //6699//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
Apr 28 17:15:20.391: //6699//AFW_:/vtr_lg_dnis: argc 2 argindex 2
Apr 28 17:15:20.391: //6699//TCL :/tcl_InfotagObjCmd: infotag set med_language 1
Apr 28 17:15:20.391: //6699//TCL :/tcl_InfotagSetObjCmd: infotag set med_language 1
Apr 28 17:15:20.391: //6699//AFW_:/vtw_ms_language: argc 3 argindex 2
Apr 28 17:15:20.391: //6699//TCL :/tcl_LegObjCmd: leg setupack leg_incoming
Apr 28 17:15:20.391: //6699//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
Apr 28 17:15:20.391: //6699//AFW_:/vtd_lg_incoming: argc 2
Apr 28 17:15:20.391: //6699//AFW_:/vtd_lg_incoming: Legs [6699 ]
Apr 28 17:15:20.391: //6699//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
From a mobile phone call we got the same debug as above and:
Apr 28 17:15:39.891: //6702//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
Apr 28 17:15:39.891: //6702//PACK:/tcl_MediaObjCmd: media play leg_incoming _night-tmp-msc.au
Apr 28 17:15:39.891: //6702//PACK:/tcl_MediaPlayObjCmd: play leg_incoming _night-tmp-msc.au
Apr 28 17:15:39.891: //6702//AFW_:/vtd_lg_incoming: argc 3
Apr 28 17:15:39.891: //6702//AFW_:/vtd_lg_incoming: Legs [6702 ]
Apr 28 17:15:39.895: //6702//PACK:/Media_Play_Start:
Apr 28 17:15:39.967: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 3xxxxxxxxx N/A
Apr 28 17:15:42.067: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0 disconnected from 3xxxxxxxxx , call lasted 2 seconds
Apr 28 17:15:42.075: Potential Mute Call:
Apr 28 17:15:42.075: CallID1=6700; CallID2=6701; ConfID=2212
Apr 28 17:15:42.075: Leg 1: CallID=6700; TX packets: 106; RX packets: 107
Apr 28 17:15:42.075: Leg 2: CallID=6701; TX packets: 107; RX packets: 106
Apr 28 17:15:42.079: //6702//TCL :/tcl_CallObjCmd: call close
Apr 28 17:15:42.079: //6702//TCL :/tcl_CallCloseObjCmd: close
Attached there is the act_Setup procedure.
The script failed even if it is configured under the DP associated to the serial voice port, or it is reached directly from the PSTN not with CFA, with num-exp, as specified in original post, or configuring the E.164 number as "destination-pattern" and "incoming-called number" under loopback DP 500.
Thanks a lot.
Marco.
Actually, I would need to see the entire script. I suppose it handles ev_media_done to wait for the message to be played before closing the call, but without seeing it, I can't tell.
As I said, if you attach, for example, aa-bacd to CF numbers, it works OK.
Hello Paolo,
Yes, the FSM machine is set up for ev_media_done in order to wait for the message to be played before closing the call, as you can see in the attached script.
Thanks.
Hi Marco,
I will look at this as I have the time, good luck!
Hello Paolo,
While I'm waiting for your results, can I ask if you are almost sure that it's a script problem?
Thanks a lot as usual!
Marco.
