My localities are wrong in signature events
Answered Question
Apr 30th, 2007
In my viewed events on the IPS module my localities are incorrect. It always lists internal addresses as OUT rather than IN. I've looking through the configuration and docs but only found the AD internal/external zone settings - which are correct anyway.
Where or how does the IPS learn what is inside and what is outside? Would it exhibit this behaviour if I've only got the security policy for traffic sent to the IPS module enabled for just the outside interface?
Correct Answer by mhellman about 9 years 12 months ago
In the network IPS sensor, you define the networks using event variables. Everything not defined is OUT. I would guess based on the behavior you're seeing that the module is the same.
Overall Rating: 5 (1 ratings)
Correct Answer
mhellman Mon, 04/30/2007 - 06:04
  • Blue, 1500 points or more
jason.scott Wed, 05/02/2007 - 06:08
Thank you, I thought the sensor was incorrectly seeing internal traffic as external. I've added an event variable for our internal subnets and its now showing in the event logs.
