Router Redundancy
Answered Question
Apr 30th, 2007
I'm looking to introduce redundancy in our ISP routes. What I'd like to do is have two routers, I'm looking 2851's and have a separate ISP links into each router. So for e.g:
ISP1--------ISP2
Router1-----Router2
Switch1-----Switch2
Firewall1---Firewall2
(Strange this digram comes out skewed once I post this, I hope you get the idea though)
Any Ideas how this could be implemented on the router, and what type of routing to implement,, e.g hsrp etc. Also I will be running BGP between each ISP. Additionally I'd want all traffic to go through ISP1 and if that fails then all traffic should be routed through ISP2.
Thanks in advance
Dan
Correct Answer by mohammedmahmoud about 10 years 3 months ago
Hi Dan,
PI: Provider Independant IPs, you can advertise them to any provider as they are attached to your AS, used for customer multihoming scenarios.
For your case, the link provided by "Bjornarsb" shall be great:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080093f2c.shtml
In brief HSRP will do the job for the outbound traffic, and AS path prepend will do the job for the inbound traffic, review it and don't hesitate if you have any further questions.
HTH, please rate if it does help,
Mohammed Mahmoud.
Correct Answer by bjornarsb about 10 years 3 months ago
Hi Dan,
The implementation you are looking for is called: multihomed Border Gateway Protocol (BGP).
Please have a look at this web page:
Please rate helpfull posts !
Bjornarsb
Overall Rating: 5 (2 ratings)
mrefahmrefah Mon, 04/30/2007 - 01:29
Dear DAN,
I offer you policy base routing for outgoing traffic from your network.
see track documnets.icmp reachibility.
sh trach and define trach .
I have sample config if you need.
dan_track Mon, 04/30/2007 - 02:08
A sample config would help me out a lot. I would appreciate it if you could send me it.
Many Thanks
Dan
mohammedmahmoud Mon, 04/30/2007 - 01:51
  • Green, 3000 points or more
Hi Dan,
Do you have your own AS and IPs (PI) ?
BR,
Mohammed Mahmoud.
dan_track Mon, 04/30/2007 - 02:07
Yes I have my own AS and IP's. BTW what's PI?
Dan
Correct Answer
mohammedmahmoud Mon, 04/30/2007 - 04:00
Hi Dan,
Mohammed Mahmoud.
