bjornarsb Mon, 04/30/2007 - 02:50
  • Bronze, 100 points or more
A VTP domain (also called a VLAN management domain) is made up of one or more interconnected switches that share the same VTP domain name. A switch can be configured to be in one and only one VTP domain.
If your switch is set up in your existing vtp domain you configure the old switches as VTP transparent, you can create and modify VLANs but the changes affect only the individual switch.
See: http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_guide_chapter09186a008007fa37.html#xtocid12
Bjornarsb
csco123456 Mon, 04/30/2007 - 02:56
hi
my problem is some of my user plug their switch to my switch as client. is there a way i can prevent it by putting some config in my switch ports?
bjornarsb Mon, 04/30/2007 - 03:19
Then I would suggest that you set a password
for the VTP domain:
vtp passwd passwd
Bjornarsb
mahmoodmkl Mon, 04/30/2007 - 03:57
  • Gold, 750 points or more
I think u can even use bpdu guard.
Mahmood
