Public IP Routing
Apr 30th, 2007
I am trying to install 4 cameras with static ip and routing to a single STATIC PUBLIC IP.
Need an advise which router model should I consider to do the task.
Overall Rating: 3.5 (2 ratings)
johnrages Mon, 04/30/2007 - 04:22
I am not really sure if the idea I have in mind is the same as the specification and information provided by cisco 851 router. Need your further advise. The setup should be:
1 WAN IP routing to 4 static private IP.
mohammedmahmoud Mon, 04/30/2007 - 04:39
  • Green, 3000 points or more
Any router from the 800 series shall do the job for you, but you'll need to get back to your provider to know the WAN Interface that he supports, plus you have to consider do you want the 802.11b/g wireless (available only for 851, 857, 871, 876 and 878) or not (805, 828, 831, 836 and 837).
HTH, please rate if it does help,
Mohammed Mahmoud.
johnrages Mon, 04/30/2007 - 04:49
Basically what are the basic and standard WAN interface is using by providers? As of the moment wireless connection is not yet in the plan.
Also, I will ask my providers what WAN interface that they support.
mohammedmahmoud Mon, 04/30/2007 - 04:53
The most common WAN technologies are ADSL and G.SHDSL.
Contact your provider, and good luck.
Mohammed Mahmoud.
