Is it poss to get external inbound calls to retain their external flag.....
Answered Question
Apr 30th, 2007
... when transferred internally?
Scenario:-
The customer has CFWD NA and BSY on External calls set to send calls back to reception, however when reception blind transfer external calls to an extension forwarded as such, they appear to be flagged as internal calls and are then not forwarded back to reception (DDI calls are fine) they could apply the rules for internal calls as well but this would then inundate Reception with internal calls which they don't want. They are running 4.1.3sr4d at this remote site.
I have raised this with Cisco and they have responded with expected behaviour even with 4.2, but I'm not too sure as I don't think this is an unusual request!
Anyone any ideas or workarounds?
Correct Answer by Brandon Buffin about 10 years 3 weeks ago
We had the same issue and ended up using 2 lines on each phone. Internal callers call one line which has CFNA for internal calls to VM. This is also the DID line and has CFNA for external calls set to the receptionist. Receptionist transfers external calls to second line which has CFB/CFNA back to receptionist.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Fri, 05/04/2007 - 06:41
  • Purple, 4500 points or more
Hope this helps.
Brandon
agster Fri, 05/04/2007 - 07:14
Good stuff... a definite example of lateral thinking outside the box.
Thanks for that.
Andrew
