WCS 4402 session timeout
pcanters
I was wondering if anyone knows the answer to this.
I am using a 4402 and on my guest WLAN there is a session timeout value. I am not using the web authentication.
After 10 mins of inactivity, I want to drop the session or re-authenticate the client. This appears to be happening behind the scenes. Is there anywhere that I can tell that the re-auth is happening ??
Either on the client or on the 4402 ?
I need some sort of way to prove that this is actually happening and not just smoke and mirrors.
Does anyone know where I can find this.
Thanks in Advance for the help !
Rob Huffman
Hi Pieter,
On the WLC
The session timeout parameter in the WLAN > Edit page can be used to accomplish this. By default the session timeout parameter is configured for 1800 seconds before a reauthentication happens.
Change this value to 600 seconds in order to make the client reauthenticate after ten minutes.
WLANs > Edit
This page allows you to edit the configurable parameters for a WLAN. The WLAN ID and WLAN SSID are displayed at the top of the page.
Session Timeout
Set the maximum time for a client session before requiring reauthorization. Default = 1800 seconds.
From this doc;
http://www.cisco.com/en/US/products/ps6366/products_user_guide_chapter09186a00805a6b28.html#wp1040213
Hope this helps!
Rob
Rob,
Thanks for your response.
One last follow up question
Is there any way that I can verify that this re-authentication is actually happening on either the WLC or on the client itself ?
The setting seems to indicate that this re-authentication is supposed to happen but I need to corroborate in some way that this is truly occuring.
Pieter
Rob Huffman
Hi Pieter,
That is an excellent question! If you know the Client mac you could probably use this;
(Cisco Controller) >show client detail 00:40:96:a9:fa:a0
Client MAC Address............................... 00:40:96:a9:fa:a0
Client Username................................. N/A
AP MAC Address................................... 00:0b:85:23:cc:50
Client State..................................... Associated
Wireless LAN Id.................................. 1
BSSID............................................ 00:0b:85:23:cc:50
Channel.......................................... 36
IP Address....................................... Unknown
Association Id................................... 1
Authentication Algorithm......................... Open System
Reason Code...................................... 0
Status Code...................................... 0
Session Timeout.................................. 1800
Re-Authentication Timeout........................ 1800
Remaining Re-Authentication Time................. 1790
QoS Level........................................ Silver
Diff Serv Code Point (DSCP)...................... disabled
802.1P Priority Tag.............................. disabled
Mobility State................................... Export Foreign
Mobility Anchor IP Address....................... 40.1.3.10
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... No
Policy Type...................................... N/A
Encryption Cipher................................ None
EAP Type......................................... Unknown
Interface........................................ guest-vlan
VLAN............................................. 60
From this doc;
http://www.cisco.com/en/US/products/ps6366/prod_technical_reference09186a0080706f5f.html#wp1111008
Hope this helps!
Rob
Thanks Rob !!
The whole thing is vague but this ought to work.
