3000 concentrator question
Apr 30th, 2007
Good day;
I have a quick question...I have a Lan-to-Lan VPN connection we are using 3000 VPN concentrators on both sides. The set up is the same as well:
firewall => concentrator
The question is I can initiate with no problems tunnel comes up and we are good but he cannot initiate on his side, port 500 is allowed on both firewalls...anyone run into this problem before?
Overall Rating: 4 (1 ratings)
Richard Burts Mon, 04/30/2007 - 08:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Warren
I am not sure if it is the same but I have had a similar experience. I suggest that you check ISAKMP and IPSec parameters between the 2 concentrators, especially the timers, and verify that they match.
Rick
wgranada1 Mon, 04/30/2007 - 08:59
HI Rick;
thanks for the info, will double check the timers as stated. Will let you know what happens
warren
