LMS Dont let me in.....
Apr 30th, 2007
hi: im new in cisco aplications, but i manage miself to install and make work LMS, updates, devices and all, well it was working perfectly, but i installed an MRTG server in the same LMS server, since then LMS doesn`t let me in.. after i put my name and pass gives me this error:
Forbidden
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
Its driven me crazy cause it was a lot of work for me to make lms work completly, and i really dont want to do all over again. The thing is y dont think my backup its ok, so it`s not an option. Does anybody knows what append??
PD: sorry for my lousy english... english is not my languaje.
Daniela
jreekers Tue, 05/01/2007 - 10:32
Hi Daniela.
Is there a possibility that you are running Virus Scanning software on the server? If so, please completely uninstall the virus scanning software and see if that fixes the problem.
HTH,
-Joe
