sup 720 sso rpr
Apr 30th, 2007
I have 2 sup720, I read the documentation of 6509 but I found information of how can I configure SSO and RPR mode, and it works , But I didn't found a documentation who explain me and gives advices about why or why not I use SSO or RPR.
Overall Rating: 5 (1 ratings)
Iain Mon, 04/30/2007 - 06:36
The guy at TAC told me I needed NSF/SSO (see NSF section of config guide). Once you have it configured, it would be smart to conduct a test of the failover. Obviously you would probably want to do this during a planned outage just in case.
Note: Remember to add the 'NSF' statement to your route processes.
redundancy
mode sso
main-cpu
auto-sync running-config
auto-sync standard
router eigrp 123
nsf
Output for 'show redundancy'
Redundant System Information :
Available system uptime = 15 weeks, 2 days, 5 hours, 45 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = sso
Operating Redundancy Mode = sso
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 5
Current Software state = ACTIVE
Uptime in current state = 15 weeks, 2 days, 5 hours, 45 minutes
Image Version = Cisco Internetwork Operating System Software
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Mon 18-Sep-06 23:59 by tinhuang
BOOT = sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF6.bin,1;
CONFIG_FILE =
BOOTLDR =
Configuration register = 0x2102
Peer Processor Information :
Standby Location = slot 6
Current Software state = STANDBY HOT
CONFIG_FILE =
BOOTLDR =
eric.loiseau Mon, 04/30/2007 - 07:14
Thanks for your reply.
In my case I use statics routes, but why not rpr+.
ankbhasi Mon, 04/30/2007 - 10:17
  • Cisco Employee,
Hi Eric,
Have a look at this and you will get a clear picture of difference between RPR , RPR+ and SSO
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a00800c8441.shtml
After this link is open search for keyword "Supervisor Redundancy".
After reading this link if you have any doubts please come back with them.
Ankur
*Pls rate helpfull post
