NI2 PRI 7 Digit local calling
Apr 30th, 2007
I am having trouble with a PRI making outbound local 7-digit calls. I have a PRI connected to ccm with MGCP protocol. I can dial 10 digit (area code plus number) fine, but am getting rejected when using 7.
According to Telco, I should have the ability to dial either / or. Any ideas?
Overall Rating: 3 (2 ratings)
Brandon Buffin Mon, 04/30/2007 - 06:46
  • Purple, 4500 points or more
Do you have a route pattern in place for 10 digit such as 9.[2-9]XX[2-9]XXXXXX and are you stripping the 9 before sending the call?
Brandon
hauchinango Mon, 04/30/2007 - 07:26
Brandon,
I was using the 9.@ pattern. I created a 9.[2-9]xxxxxx pattern for 7 digit local and it works.
lfulgenzi Mon, 04/30/2007 - 15:23
  • Silver, 250 points or more
For 7 digit dialing to work with 9.@ patterns you need to add a route filter which has the clause "local area code does not exist". This will prevent 10 digit dialing so you will need to add another 9.@ pattern or a similar route pattern with wildcards.
