Removing deleted CSA Kits for faster rule generation
Apr 30th, 2007
  • Bronze, 100 points or more
I had to customize all the agent kits due to application requirements. However, I notice the deleted agent kit are still being compiled during a rule generation. Is there any way to purge them ?
Overall Rating: 4 (1 ratings)
tsteger1 Mon, 04/30/2007 - 15:51
  • Red, 2250 points or more
Try deleting the .exe files from the server.
tsteger1 Tue, 05/01/2007 - 11:34
Don't remove CSAAgentkit.exe though or you'll get an error when generating rules. I believe it's the base agent kit that custom kits are created with. You won't see it referenced during rule generation or listed in the kits.
It would be safer to move them, not delete them. That way you can restore them quickly if there are problems.
Sorry for any confusion,
Tom
