Why no info on "TCP reassembly queue overflow"
Apr 30th, 2007
I'm getting syslog messages from IOS 12.4(9)T3 that I can't figure out what to do with, e.g.:
%FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1102628888 576 bytes is out-of-order; expected seq:1102605840. Reason: TCP reassembly queue overflow
I've searched and couldn't find any reference anywhere regarding "TCP reassembly queue overflow".
1. Why are there messages in IOS that appear to be completely undocumented?
2. If they are something I should act upon, what kid of actions are appropriate?
3. If not, and they aren't causing me problems, I'd rather not receive them -- how do I accomplish that?
sachinraja Mon, 04/30/2007 - 23:50
  • Red, 2250 points or more
have u checked if the ios has any caveates ? might be a software bug... have u enabled IPS on your router ? this can happen if you have IPS turned on with less re-assembly limit... you can have this parameter tweaked with the "ip inspect tcp reassembly" command, given on the following URL
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124newft/124t/124t11/ht_ooop.htm#wp1051333
Hope this helps.. all the best..
Raj
kwallewein Wed, 05/02/2007 - 16:21
Yes, I am running IPS. Your suggestion makes sense -- the reassembly queue was at defaults. Doesn't explain the lack of documentation, though. I have trouble understanding why the IOS development team doesn't have a rule that all error messages must be documented. Seems like a no-brainer....
Oh,wait, all IOS messages are intuitively obvious, right?
Reminds me of a programmer I once knew who refused to document properly. Figured it was job security. Is that what makes IOS so inscrutable?
sectel123 Wed, 10/07/2009 - 18:40
yes I agree. ALL, error messages and warnings should have hints and/or tips
ie
ip inspect log drop-pkt
ip inspect max-incomplete high 8000
ip inspect max-incomplete low 7900
ip inspect one-minute high 8000
ip inspect one-minute low 7900
ip inspect udp idle-time 360
ip inspect dns-timeout 10
ip inspect tcp idle-time 7200
ip inspect tcp max-incomplete host 250 block-time 1
ip inspect tcp reassembly queue Length 128
