CW LMS 2.6 RME JOB and access-list management issue
Apr 30th, 2007
Hi all,
Okay I'm trying to add some access-list entries with the Baseline template Job under the Archive Management of the RME (LMS2.6)
the issue is I have an access-list there
access-list 100 permit ip host X.X.X.X any
access-list 100 deny ip any any log
and I want to add that entry:
access-list 100 permit ip host Y.Y.Y.Y any
the issue is that the JOB add the entry at this end of the existing access-list:
instead of put the permit before the deny
do I have any way to have the order of all permit before the deny ?
like that:
if not the last permit will have never been used.
thanks in advance for any help, I really appreciate any solutions.
Matt
Overall Rating: 5 (1 ratings)
jreekers Mon, 04/30/2007 - 16:06
  • Cisco Employee,
Hi Matt.
I see you're running LMS 2.6, can you please tell me what version of RME you're running?
-Joe
subrin_matt Tue, 05/01/2007 - 23:14
Hi Joe,
I'm using the RME 4.0.5.
but I find antoher solution to do that because I need to do that before end of week.
so I will use the resequence access-list feature to insert the entry I need myself and deploy that with NetConfig.
it will be something like that:
enable
conf t
ip access-list resequence ZZZ 10 15
ip access-list extended ZZZ
15 permit ip host y.y.y.y
with the deny above 15
but if you know a way with the baseline It will help me in future :-)
thanks
jreekers Wed, 05/02/2007 - 06:23
  • Cisco Employee,
Hi Matt.
The reason I was asking was because there was a known issue (bug) in RME 4.0.3, but it was fixed in the later versions around this issue. Since you're running RME 4.0.5, I'm thinking that you probably aren't hitting the bug I was suspecting.
Your workaround is good. I'll see if there are other bugs around this issue, and let you know if I find anything.
-Joe
