Exchange 2007 Compatibility?
Brandon Buffin Mon, 04/30/2007 - 11:08
That is correct. Exchange 2007 will be supported beginning with Unity 5.0 which should be out in the next few months. There is no temporary solution that I'm aware of.
Hope this helps. If so, please rate the post.
neesharm Mon, 04/30/2007 - 20:31
Yes Exchange 2007 is ONLY supported with unity 5.0.
Check Link
I would not recommend running exchange 2007 on a production unity (4.x).It might work but again you taking the risk for running unsupported software(plus exchange 2007 is quite new which might be buggy also)
I guess you can contact Cisco Representative for unity 5.0 availability or contact your cisco presales.
As far as I know there is no temporary fix ...I hope it doesn't ruin your day
