802.1p on 3750G-24TS
Apr 30th, 2007
Hi all,
I have some problems for the configuration SW 3750 support 802.1p. Please help me
I have 3 VLAN (10,20,30) on this switch and i want to apply 3 values CoS on them, for example 6 for VLAN10, 5 for VLAN 20 and 4 for VLAN30 but i don't know how to build it.
Please tell me any suggestion or any helps.
Overall Rating: 4 (1 ratings)
royalblues Mon, 04/30/2007 - 10:11
  • Green, 3000 points or more
you can do something like this
ip access-list extended vlan10
permit ip any
ip access-list extended vlan20
permit ip any
ip access-list extended vlan30
permit ip any
class-map match-all VLAN10
match access-group name vlan10
class-map match-all VLAN20
match access-group name vlan20
class-map match-all VLAN30
match access-group name vlan30
policy-map set-cos
class VLAN10
set precendence 6
class VLAN20
set precendence 5
class VLAN30
set precendence 4
Apply this policy on the interfaces
interface fa0/1
service-policy input set-cos
HTH, rate if it does
Narayan
intermediasud Wed, 05/02/2007 - 06:27
Thanks so much for your solution but I have also a question for you:
I want to work on 802.1p, it means apply COS to .1Q or ISL header but why you used "set precedence" that in IP header.
Thanks for your time and your answer
