CTI Route Point
Answered Question
Apr 30th, 2007
Is there a step to register the CTI route point with the server after you define it?
Correct Answer by thisisshanky about 10 years 2 months ago
All CTI Rp's dont register to the Callmanager unless an application using CTI is associated with that RP. If you are using the following apps, the RP will register.
a. IPMA
b. IPCC/ICM Route points associated with applications
c. Mobility Manager
d. Attendant console pilot point is a route point in CM 5.x. This RP will show registered in CM.
Sankar.
PS: please remember to rate posts!
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 04/30/2007 - 10:16
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jeff,
After you Insert the CTI RP and add the DN you will use Update/Reset. It make take a few moments to register with Callmanager (are you having problems getting it to register?).
Cisco CallManager Administration Guide, Release 4.1(3)
CTI Route Point Configuration
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed6d3.html#wp1122418
Hope this helps!
Rob
jowenjowen3 Mon, 04/30/2007 - 10:19
Yes, I reset it 2 or 3 times and still cannot get it to regisiter with CM
Correct Answer
thisisshanky Mon, 04/30/2007 - 10:40
  • Purple, 4500 points or more
a. IPMA
c. Mobility Manager
Sankar.
