Application service problem
For night service we have created a loopback voip dial-peer to with an application service that prompts a message during after hours.
During working hours the same DP will prompt a waiting message.
So the DP is called by setting up a "call-forward noan 5500 timeout 20" where 5500 is the number associated to the loopback voip DP.
Here is the DP configuration:
dial-peer voice 500 voip
service script1
destination-pattern 5500$
session target ipv4:192.168.1.1 <-- this is the router ip address (IF Gi0/0)
incoming called-number 5500$
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
The voice service voip is configured as follows:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
h450 h450-2 timeout T4 10000
h450 h450-3 timeout T1 10000
h245 caps mode restricted
modem passthrough nse codec g711alaw
sip
When the call starts from internal ephone or from outside mobile phones, the prompt is regularly played.
But when the call comes from an outside fixed phone, the call is disconnected just after the timeout for call-forward is expired.
We have also tried to configure a number expansion to call directly the DP 500 adding the following command to the configuration:
num-exp 2xxxxxx98 5500
but obviously the behavior does not change.
With "debug q931" we see that the call is disconnected with Disconnect Cause 10 (normal call clearing):
Apr 27 18:45:09.361: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x2500
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18387
Preferred, Channel 7
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x2183, '2xxxxxxx'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '2xxxxxx98'
Apr 27 18:45:09.365: ISDN Se0/0/0:15 Q931: TX -> SETUP_ACK pd = 8 callref = 0xA500
Channel ID i = 0xA98387
Exclusive, Channel 7
Apr 27 18:45:09.393: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xA500
Cause i = 0x8090 - Normal call clearing
Apr 27 18:45:09.461: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x2500
Apr 27 18:45:09.461: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xA500
Any ideas?
Thanks a lot.
Marco.
thisisshanky Mon, 04/30/2007 - 10:57
  • Purple, 4500 points or more
Is this a TCL script ? Custom developed or BACD ?
Does the script look at a particular DNIS on the call ? Instead of using 5500 on the dial-peer i have seen with BACD that you have to use the actual DNIS *2XXXXXX98" on the incoming called number statement.
Hi and thanks for your reply.
Yes,it's a TCL script and it's a customization of one script that comes with Stone Voice suite.
The script accept the call
leg setupack leg_incoming
leg proceeding leg_incoming
leg connect leg_incoming
and then recall media play to play the prompt, repeat the prompt another time and after the second play it closes the call with "leg disconnect leg_incoming".
In the test we have done we have enabled the "debug voip app tclcommnads". When a call comes from a mobile phone the script was called and proceed succesfully.
But when the call comes from a fixed phone number, the debug print messages up to the "leg setupack" statement. The call is disconnected with a "clear disconnect cause".
Attached, you can find the debug related to the two tests, from a mobile phone and from a fixed one.
The answer to your second question:
It does not referer at a particular DNIS on the calls.
We already tried to set up the "incoming-called number" and the "destination-pattern" with the complete E.164 number under the loopback voip DP (i.e. 2XXXXXX98) , instead of num-exp parameter at global level.
But we got the same results.
Thanks a lot.
Marco.
