Security Wireless 857w router config.
Apr 30th, 2007
I do have adsl & wireless internet connection running properly under my Cisco 857w router.
However, I am trying to configuring with out success the (wap), my wifi internet connection still open for everyone.
I will really appreciate your advices.
Thanks in advance.
supergrip7 Fri, 05/04/2007 - 12:30
Hi Brandon,
Thanks for your response, but unfortunally I could not setup my Wireless Security yet.
With the following config I am unable to connect with my laptop:
Encryption mode: "Cipher TKIP"
Authentication Key Management:
Key Management: "Mandatory" "WPA"
WPA Preshared key: "xxxxxxxxx" "ascii"
I mean, if I want to connect with my laptop via wifi the router encryption modes need to be configure to (none).
Here below I attached my router config, maybe you can see what is wrong on it.
Thanks in advance.
supergrip7 Fri, 05/11/2007 - 10:14
Hi all,
I am still not find the solution for my wifi security config.
I need your advices.
Thanks in advance.
