IPM - question about udpEcho
Apr 30th, 2007
I have small problem with IPM. When I create new udpEcho Collector, this collector have "Control Packet" set to "Disable".
Does anybody know how I can set this feature to "Enable".
Joe Clarke Mon, 04/30/2007 - 18:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is expected. IPM will not enable control packets for standard UDP echoes since the target address is expected to have something bound to UDP port 7 (i.e. the echo port) to answer the probes.
If the target is an IOS device, you can enable "service udp-small-servers" which will enable the echo service.
