What new device should I replace my EoL AS5300 with?
Apr 30th, 2007
I'm looking to replace an old AS5300 with one of the new AS5350 Universal Gateways, but I don't know which one will provide me with the same functionality. The show ver output just says it's an AS5300, not which model (see below).
#sh ver
IOS (tm) 5300 Software (C5300-JS-M), Version 12.2(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 15-Jan-02 13:43 by pwade
Image text-base: 0x600089B0, data-base: 0x61250000
ROM: System Bootstrap, Version 11.2(9)XA, RELEASE SOFTWARE (fc2)
BOOTLDR: 5300 Software (C5300-BOOT-M), Version 12.1(13), RELEASE SOFTWARE (fc3)
uptime is 1 year, 15 weeks, 1 day, 7 hours, 39 minutes
System restarted at 02:09:30 AEST Sun Jan 15 2006
System image file is "flash:c5300-js-mz.122-7.bin"
cisco AS5300 (R4K) processor (revision A.22) with 131072K/16384K bytes of memory.
Processor board ID 07390725
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 1.0, Item Number 73-2414-03,
Board Revision A0, Serial Number 07390725,
PLD/ISP Version <unset>, Manufacture Date 3-Jan-1998.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
93 Serial network interface(s)
60 terminal line(s)
4 Channelized E1/PRI port(s)
128K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
It has 4 E1 ports and, I believe, 60 MICA modems. Which AS5350 should I purchase?
Thanks in advance.
Overall Rating: 5 (1 ratings)
jonathan.york Tue, 05/01/2007 - 14:29
Thanks, but I'm not sure which model I should be buying. The EoL notice has many different models of old AS5300 and the recommended replacement for each, but I'm not sure which one I've got.
Richard Burts Tue, 05/01/2007 - 20:07
I agree with Sundar that the 5350XM is the replacement that you should look at. Perhaps if you post the link to the EoL notice that you mention we could look at it and do a better job of interpreting it for you.
