Traffic in the PIX 525
After get following error in the BEA Welogic app server in the dmz:
"<BEA-101215> <Malformed Request "/jsp/AD_Banner/Hardocp_120x300.jsp HTTP/1.0". Request parsing failed, Code: -10>".
app server is still running fine, but traffic in the PIX (version 7.0) inside interface, two dmz interface and failover interface have big jump, PIX cpu usage is from 20% to 80%, after 8 hour, everything is back to normal. Is this bug with PIX or somethng else?
ben
sachinraja Mon, 04/30/2007 - 22:03
  • Red, 2250 points or more
Hello Ben
The release notes of all the pix ios versions are as given below:
http://cisco.com/en/US/products/sw/secursw/ps2120/prod_release_notes_list.html
you can look for your specific IOS and see if there are any open caveats.. anyway, can you please eloborate a little more on your issue ? I really did not get much, apart from the fact that the CPU goes from 20 % to 80 %...do you see anything on the local logs ? how is the interface traffic ??
Raj
Thanks Raj.Follwoing is details for traffic in the interface with MRTG (have dmz1, dmz2,dmz3, inside, outside, failover):
Outside and dmz3 interface: Normal
dmz1: incoming traffic from 0.2M up to 1.6 M(it's about 0.2 M normaly)
outgoing traffic: Normal
dmz2: Incoming traffic: Normal
outgoing traffic from 0.2 M up to 1.6 M (it's about 0.2 M normaly).
Failover: incoming traffic: Normal
outgoing traffic from 0.2 up to 2.2 M (it's about 0.2 M normaly).
Inside interface: incoming traffic: 0.5 M up to 2.8 M (it's from 0.5 to 1 M normaly).
outgoing traffic: 1.0 up to 5.5 M (it's from 0.5 to 3 M normaly).
From pix syslog, not find anything about it. Only find error message in the app server which with first email.
* Normal: just compare traffic with day or weekly traffic graphic and no more big changed.
Looks traffic is not with outside, it is with inside.
ben
