reg:fxs to fxo
Apr 30th, 2007
Dear sir,
iam having 2811 router and 2611 xm router these routers r connected back to back
using null modem cables in that routers having fxo and fxs cords how can i configure
these cords using pbx and normal analog phones plz send me the examples.
mohammedmahmoud Mon, 04/30/2007 - 23:09
You will have to configure, dial-peers on each router (pots - for local lines and voip - for remote numbers), check the basic configuration in this simple guide, it shall do it for you:
Router(config)# dial-peer voice 1 pots
Router(config-dial-peer)# destination-pattern 14085554000
Router(config-dial-peer)# port 0/0
Router(config)# dial-peer voice 2 voip
Router(config-dial-peer)# destination-pattern 13105551000
Router(config-dial-peer)# session target ipv4:
HTH, please rate if it does help,
Mohammed Mahmoud.
