c3750 IOS upgrade
May 1st, 2007
not sure if this is the right place for this problem, but i'd be very much obliged if i can get the help i need. Yesterday, i upgraded the IOS image on my 3750 switch, and scheduled the reload to take place at midnight, but only for me to get to the office today and find out that it's still running the old image. Was there something i didnt do right? Please find below the old and new image, and so show commands i pasted:
IOS (tm) C3750 Software (C3750-I9-M), Version 12.2(20)SE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Sun 09-Jan-05 00:09 by antonino
Image text-base: 0x00003000, data-base: 0x0099748C
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEA, RELEASE SOFTWARE (fc)
Tunwells_Cat uptime is 24 minutes
System restarted at 08:54:32 BST Tue May 1 2007
System image file is "flash:c3750-i9-mz.122-20.SE4/c3750-i9-mz.122-20.SE4.bin"
cisco WS-C3750-24P (PowerPC405) processor (revision F0) with 118784K/12280K bytes of memory.
Processor board ID CAT0915Z0JP
Last reset from power-on
3 Virtual Ethernet/IEEE 802.3 interface(s)
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:13:C3:E6:A9:80
Motherboard assembly number : 73-9672-06
Power supply part number : 341-0029-03
Motherboard serial number : CAT091406DR
Power supply serial number : DTH09115PKN
Model revision number : F0
Motherboard revision number : A0
Model number : WS-C3750-24PS-S
System serial number : CAT0915Z0JP
Top Assembly Part Number : 800-25860-02
Top Assembly Revision Number : A0
Version ID : V03
CLEI Code Number : CNMV1K0CRB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3750-24P 12.2(20)SE4 C3750-I9-M
The new image is
Thanks in advance.
mohammedmahmoud Tue, 05/01/2007 - 00:37
Did you add a new boot statement pointing to the new IOS.
"boot bootflash:c3750-advipservicesk9-mz.122-25.SEE2.bin "
HTH, please rate if it does help,
Mohammed Mahmoud.
achalante Tue, 05/01/2007 - 00:40
I'll try this out before the end of the day.
Do i need to add the boot before the flash i.e boot bootflash: (as opposed to boot flashh:)
mohammedmahmoud Tue, 05/01/2007 - 00:44
Ok, then 100% this was your problem, as when the switch boots, if there is no boot command it uses the first image it founds in flash, which was in your case the old one.
yes the command syntax is "boot :"
note that the device here is the device where you've installed your new IOS, it may be the bootflash: or slot0: or disk0:.
And don't forget to save your configuration.
Mohammed Mahmoud.
