csico 2600 <-> checkpoint ipsec vpn tunnel ACL port based
May 1st, 2007
Dear All,
in this post i have two questions related to my vpn config.
* ipsec VPN1 to third party with pki/rsa
** Tunnel over Loopback and use of NAT
* ipsec VPN2 to third party with sharedkey
** No tunnel direct routing / no nat
my questions are based on the config below:
* for VPN2 is the direct ipsec routing properly configured? i do see it working but in most example configs i see the nonat section also applied. for me it also works without. do i need it?
* for VPN2 i have this acl sextion:
ip access-list extended vpn2add1
permit ip internalsource mask destination mask
this works. but when i try to do this
permit TCP internalsource mask destination mask eq www
then i dont get a vpn tunnel build up...!
thus trying to enable only one protocol (www) over the vpn tunnel. but when i do this, then the tunnel is not made. it only works when i do a permit IP, any attempt of filtering results in no vpn tunnel.
is this normal?, is there a way arround it? i tried searching many forums but dont really saw anyone with this problem.
and also use only permit IP.
this vpn tunnel is with a third party and i would like to block traffic from them and or only enable traffic from us over a certain port.
any help on this is greatly appriciated. i have been pulling my hairs out for a couple of days now.
cisco config:
crypto isakmp policy 1
authentication rsa-encr
lifetime 900
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key (***REMOVED***) address (***REMOVED***)
crypto isakmp keepalive 30
crypto ipsec transform-set vpn1set1 esp-3des esp-sha-hmac
crypto ipsec transform-set vpn2set esp-3des esp-sha-hmac
crypto map cryptomap1 local-address FastEthernet0/0
crypto map cryptomap11 ipsec-isakmp
set peer (***REMOVED***)
set security-association lifetime seconds 900
set transform-set vpn1set1
match address cryptomap1
crypto map cryptomap110 ipsec-isakmp
set transform-set vpn2set
set pfs group2
match address vpn2add1
crypto map cryptomap111 ipsec-isakmp
set pfs group2
match address vpn2add2
interface Loopback1
ip address (***TUNNELLOCALADDRESS***) 255.255.255.255
interface FastEthernet0/0
ip address (***OUTSIDEIP***) 255.255.255.248
no ip redirects
ip nat outside
no ip mroute-cache
duplex auto
speed auto
interface FastEthernet0/1
ip address(***LOCALROUTERIP***) 255.255.252.0
ip nat inside
duplex auto
speed auto
no keepalive
ip nat inside source static (***LOCALADRESSOFSOURCESERVER***) (***DESTINATIONTUNNELNETWORK***)
ip classless
ip route 0.0.0.0 0.0.0.0 (***DEFAULTGW***)
ip route x.0.0.0 255.0.0.0 (***INSIDESUBNETGATEWAY***)
no ip http server
no ip http secure-server
ip access-list extended cryptomap1
permit ip (***DESTINATIONTUNNELNETWORK***) 0.0.0.255 (***INSIDEVPNNETWORK***) 0.0.0.255
permit ip (***INSIDENET1***) 0.0.0.255 (***remoteVPN2destinationet1) 0.0.0.31
permit ip (***INSIDENET2***) 0.0.0.255 (***remoteVPN2destinationet1) 0.0.0.31
permit ip host (***HOSTINSIDENET1***) (***remoteVPN2destinationet1) 0.0.0.31
permit ip host (***HOSTINSIDENET2***) (***remoteVPN2destinationet1) 0.0.0.31
ip access-list extended vpn2add2
permit ip (***INSIDENET1***) 0.0.0.255 (***remoteVPN2destinationet2)0.0.0.15
permit ip (***INSIDENET2***) 0.0.0.255 (***remoteVPN2destinationet2) 0.0.0.15
permit ip host (***HOSTINSIDENET1***) (***remoteVPN2destinationet2) 0.0.0.15
permit ip host (***HOSTINSIDENET2***) (***remoteVPN2destinationet2) 0.0.0.15
soulshepard.wazzaap Wed, 05/02/2007 - 01:48
I found my solution yesterday afterall in a previous post.
Forum Topics > Conversations > outline >
VPN Service Architectures: alternative to permit-ipsec, not using PIX
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455af2.html
these document reffere to IOS 12.4.x this version supports these commands on a crypto map. in the past i think you needed to open the ports on the outside interface. on 12.4.x this is not needed anymore.
crypto map (name) 1 ipsec-isakmp
set ip access-group (address1-in) in
set ip access-group (address1-out) out
normaly you would have:
ip access-list extended (address1)
permit local.mask remote/mask
and now you can add filtering before the ipsec tunnel with the above named access-group commands on the cryptomap for your vpn
ip accesslist extended (address1-in)
permit tcp remote/mask eq www local/mask
permit icmp remote/mask local/mask echo-reply
deny ip any any
ip accesslist extended (address1-out)
permit tcp local/mask remote/mask eq www
permit icmp local/mask remote/mask echo
deny ip any any
